'Boxy Lady' Bostonian
Re: 'Boxy Lady' Bostonian
the first new plane on new SFA! Well done.
Here is a video of one of Pete's flights with the "Boxy Lady" Bostonian at Clayton Green on Saturday.
https://youtu.be/ZyF8YlLjm4E
- Pete Fardell
Thanks for that, Tim, and good to see you yesterday.
Great little flyer Pete.
Good flight Pete.
If I may suggest, a very slightly thinner or longer rubber motor, to cure the initial power burst and the rather quick descent.
- Pete Fardell
Thanks George- I'm sure that's good advice. After the initial flights (which had an even more pronounced initial burst) I did change to a longer motor yesterday, and the flight pattern improved to what you see here. So a still longer or thinner one makes sense. As most of my other aircraft are scale ones, I'm not really used to flying such (comparitively) light models, so all advice is very welcome. In fact I get quite a kick out of only needing one loop and being able to wind beyond a thousand without even gritting my teeth!
Wow, that was a very nice flight. The Bostobina Cub will be yealous:-)
Your Boxy Lady seems to have potential.
Return to “Construction Projects”
Who is online
Users browsing this forum: No registered users and 7 guests
