Peanut floatplane, Albatros W4
Posted: Thu Dec 15, 2016 10:15 am
by Tommy
Started on a new project, which one I've had on my thoughts for a long time. Albatros W4, a floatplane from the First WW. Biplane of course, to add complexity :D
Mixed construction, foam for fuselage and probably for floats, too. Built-up wings and tail parts. Want to have a solid looking fuselage, that is the reason for foam. Besides I've never made one before. Laminated outlines for tail, used 3 mm depron as a jig. Cockpit coaming from thin depron. Covering will be Tengujo Kashmir japanese paper, got it from Ceiba sro from Czech Republic. Jiri Doležel told me that one, thanks! Link: http://eshop.ceiba.cz/japonske_papiry_archy
Hope to get this done for IIFI 2017, will see if I manage.
Tommy
Re: Peanut floatplane, Albatros W4
Posted: Fri Dec 16, 2016 11:39 am
by uhu
looks great!
Posted: Fri Dec 16, 2016 1:01 pm
Tommy,
have you had a chance to do any work with the Tengujo? I got some 8.8g from a shop in Germany a few years ago, using it on the Gipsy Moth pistachio that I had at the IIFI (didn't fly). I found that the tissue did not shrink very much - if at all. Actually, for the micro model, not a bad trait.
About the foam board you used... which type is it? The StyroDur that I have seems to be pretty heavy (can't get a weight as I only have a few scraps left, but enough for a pistachio or peanut fuselage) and has become difficult to find.
Posted: Fri Dec 16, 2016 1:33 pm
by Tommy
Hi Pete,
I used a local foam called Finnfoam. Around 32 kg per cubic meter, but mine was actually near 37 kg stuff. Slightly too heavy I think, but I can't get the light Dow Floor mate here at all. Will look around if I find something lighter. Can post to you of course!
I knew that the Tengujo won't shrink much, that was actually why I bought it in the first place. Haven't tried it yet, will soon. I've found that Esaki needs pre-shrinking, before using it to cover something. Otherwise too strong shrinkage for at least lightly built surfaces.
Tommy
Posted: Mon Dec 26, 2016 8:55 am
by Tommy
Slow progress. Made the tail parts, will most probably use the fin made from depron as it looks better. Slightly heavier, in fact now double as the built-up weighs 0.03 grams and the depron one weighs 0.06 grams. Can live with that ;-)
I can try the Tengujo on the built-up fin, just for practise.
Posted: Tue Dec 27, 2016 5:55 pm
by rgroener
Tommy, very nice looking fuselage. I dont like building with foam, but I must admit, that the smooth fuselage looks great.
I am curious to see how it looks at the end.
