Made a start on another one of these to replace my now retired (trashed) previous version. I messed up something somewhere and the formers were skew which I only saw after glueing so had to add some 1/16th stringers top and bottom of opposite sides of the rear fus to balance things out again. Not sure how it happened, but it won't be seen once covered. 2.2g so far
36" Slingsby Prefect
Re: 36" Slingsby Prefect
Look forward to progress, Monz
JM
JM
I have looked at that plan a number of times. Now after seeing your bones I think I will move it up on my list! You do beautiful work.
Thanks faif, it really is a nice little model, especially at 36".
I managed to get this 99% completed on Thursday evening. Just the wing struts and wheel to add.
I used to light a balsa for the leading and trailing edges of the wings which led to them bowing quite badly so I added a length of 1mm carbon rod right through each one. That solved it mostly. There's still a slight bow to them but I can live with it for a test model.
Covering was Hobbycraft tissue with two coats thinned banana oil to seal. With ballast to bring the CG to about 20% (that's what the old one liked for outdoors) the weight is 20.8g, less than half the weight of the old one. Now for some decent weather...
- Pete Fardell
Very nice! 20.8g sounds like an absolute feather for 36" span. You'll be in danger of losing it at that weight.
(Btw, have you started that tank glider yet?)
Yes, I remember now... 0,5 Moniques...
quick AND ggod looking too...
G
G
Pete Fardell wrote:Very nice! 20.8g sounds like an absolute feather for 36" span. You'll be in danger of losing it at that weight.
If it flies away I'll just build another
The AN-40 will start shortly
g_kandylakis wrote:Yes, I remember now... 0,5 Moniques...
G
Ah I've missed this place
Nice one Monique, I would start to make wood ready for a new one
Return to “Construction Projects”
Who is online
Users browsing this forum: No registered users and 74 guests
